Old 10-05-2019, 02:31 AM   #7
truegearhead's Avatar
If your original engine was a 1997, it had a tube coming from the oil pump housing on the front of the engine - metal tube that connected to a rubber hose somewhere near the right rear of the engine.
On the post-1997 cars that rubber hose connects to the top of the oil cooler (heat exchanger). If you look at the coolant tank, that hose is the top one directly under the oil filler.
YES! Thank you this is the other thing that has been completely stumping me (my last post was this very question. So I shouldn’t even need another line on my expansion tank.
1997 Boxster 4.2L Audi V8 Bi-Turbo
2003 911 C2
NASA HPDE Instructor
truegearhead is offline   Reply With Quote
