Old 10-01-2019, 04:14 PM   #1
PorscheBear86's Avatar
12 pin connector for door latch mech.
Dose any one know what type of connector this is? Like whats the style or name?
Also dose any one know how to dissemble? I ordered this larger version because some one gave me a link to it and said its the correct one but its larger then the original. How do i fine the correct size version?
PorscheBear86 is offline   Reply With Quote
Old 10-01-2019, 07:35 PM   #2
There Is No Substitute.
rick3000's Avatar
For the disassembly buy a terminal/pin removal tool, the pins have clips on two sides that need to be depressed to slide the pin out of the plug. If the plug doesn't have a part number, it going to be hard to source new, I would reach out to someone parting out a 986.
Old 10-01-2019, 09:15 PM   #3
On the opposite side to the hump it should have "VW 0000 Germany" then a 9 digit number. You should be able to get one. The large one you ordered is for the headlights.
derfo is offline   Reply With Quote
Old 10-01-2019, 09:17 PM   #4
You'll need a pin removal tool set - something like that:
https://www.bgstechnic.com/de/catalog/product/view/id/461398
Than you can crimp new connectors on the wires and reuse the old connector housing.
If the old connector housing is bar, did you check the 986 parts catalog for the right parts number?
https://www.porsche.com/usa/accessoriesandservices/classic/genuineparts/originalpartscatalogue/
Old 10-02-2019, 07:53 AM   #5
Awesome thank you !
Old 10-02-2019, 07:55 AM   #6
Ok cool thanks for your help !
Old 10-02-2019, 08:00 AM   #7
Thank you for your help
Old 10-03-2019, 02:40 AM   #8
Are you switching to a different type of door lock mechanism? I don't think the larger connector will fit
Woody
Old 10-06-2019, 01:03 PM   #9
no im not i ordered the wrong connector.. but i think i found the right one on ebay!
Old 10-06-2019, 09:00 PM   #10
" How do i fine the correct size version?" Sorry i missed that part. Glad you found the right one
Woody
Old 10-09-2019, 08:51 AM   #11
inveniam viam aut faciam
Soo, why do you need a new one? Did the original break? I would suggest replacing the door harness rather than splicing wiring. I bet Woody has a bunch, as well as other vendors, and they won't cost much more than just the connector...
Qmulus is offline   Reply With Quote
Tags
12 pin connector
