Old 09-24-2019, 10:47 AM   #1
I ordered a Delphi unit from local napa for $100. It was the only one they had in stock. I would prefer Bosch but at least I can try this and see if it fixes the problem. I will be reporting back shortly...
Vtx531 is offline   Reply With Quote
Old 09-25-2019, 11:16 AM   #2
I decided to order the Bosch unit instead. Now I have to wait a few days for shipping. Hope this works.
Old 09-25-2019, 02:35 PM   #3
the Bosch is A better choice in my opinion.
Well you didn't just start throwing parts at it.
Which can get costly, and is a poor way to procced.
With a little coaching you went through a diagnostic process that points at the MAF sensor.
When you get the sensor and install it, that will prove how good or bad the diagnostic method was.
Then you can keep (if good) or discard (if bad) and build on your diagnostic methodology.
There is a way to test a MAF sensor with a volt meter but I don't know the values or the procedure.
As for hoping it works- does keeping one fingers crossed help
