08-19-2019, 01:11 AM
DME water damaged
My 1999 Boxster 2.5 is fitted with a Bosch Motronic 5.2 DME. It would appear as if this DME suffered some water damage and needs to be replaced
Can I merely replace this DME with another similar DME ? If so can someone kindly provide details of stockists of such secondhand equipment.
Thank you
08-19-2019, 02:35 AM
Originally Posted by FFourie
Thank you
It has to be an exact match to the one in the car, and will absolutely require substantial coding by a dealer in order to work at all.
08-19-2019, 05:48 AM
The new DME will need to be coded to your existing key and immobilizer. This can be done by the dealer or you can ship all 3 to https://www.ecudoctors.com and they can test and do the coding for you.
08-19-2019, 08:18 AM
If goes further than that, the DME has to be coded to the car's equipment features: OBC, cruise, factory Litronics, etc. Matching the DME to the immobilizer and keys will get the car started, but then none of the other features would function.
08-19-2019, 11:33 AM
Thank you for the confirmation of re-coding of the new DME.
Any suggestions where I will find secondhand replacement units
I would start with the ecudoctors as they can repair water damaged DME's. If you give them a call they will be happy to help you.
They require the cars VIN and from that they can get the options that they need to code for.
08-19-2019, 07:32 AM
08-19-2019, 09:35 PM
Thank you for the feedback.
Where can I find ecudoctors? Contact details will be appreciated
08-20-2019, 05:54 AM
1998 Boxster Silver/Red
https://en.wikipedia.org/wiki/Google
1998 Porsche Boxster
08-19-2019, 10:37 PM
Florida...and Google.
08-19-2019, 10:38 PM
08-21-2019, 07:45 AM
You can call or text us here: 786-837-5882
Actually it'd be great if you can send us picture of the damage in the DME to see if you will need a repair or a replacement.
BTW I'm George but anyone here can help you.
Any other questions?
09-29-2019, 09:00 AM
DME water damage
Hi all,
I finally established that my DME was not water damaged but that the solenoid for the variable cam adjuster , cylinders 1 ----3 short circuited internally. This caused t damage to two drivers on the DME. The combination of the above caused the actuator to open normally but not to close properly . The result was the valve timing on bank 1 was out of spec and that resulted in the engine misfire at idling .
I had the DME repaired but am now looking for a replacement solenoid.
Any suggestions where I can find a replacement solenoid? Boxster 986 2.5 engine
09-30-2019, 06:42 AM
DME water damage
The misfiring on Bank 1 was caused by a faulty solenoid for the variable cam adjuster cylinders 1 ---3. The faulty solenoid caused damage to the DME A local electronic expert was able to effect the necessary repairs to the DME.
I now need to find a replacement solenoid. Any suggestions?
