DME water damage
Hi all,
I finally established that my DME was not water damaged but that the solenoid for the variable cam adjuster , cylinders 1 ----3 short circuited internally. This caused t damage to two drivers on the DME. The combination of the above caused the actuator to open normally but not to close properly . The result was the valve timing on bank 1 was out of spec and that resulted in the engine misfire at idling .
I had the DME repaired but am now looking for a replacement solenoid.
Any suggestions where I can find a replacement solenoid? Boxster 986 2.5 engine
