05-25-2019, 06:17 PM
Brake Fluid Change
So, if I drive the P car during spring/summer approx 5-6 months with 1,000 to 1,500 miles, store in winter does it need brake fluid change ~ 2 years?
5280 Cruising @High Altitude
Seal Gray & K&N Filter
05-26-2019, 05:06 AM
yes every 2yrs... brake fluid is hygroscopic.
You change motor oil annually, right?
Learn to DIY and it's < $20 per (plus one time cost of motive power bleeder ~ $70).
Plus, gives you opportunity to inspect all the braking components
Good luck
"Cool Prius!" - Nobody
05-26-2019, 08:57 AM
2003 S, Arctic Silver, M6
It also gives you a reason to remove your wheels and give the them a good s=cleaning on teh inside as well as inspect your suspension and other goodies that are hard to get to. Using the power bleeder makes it a one man job and a lot quicker.
05-27-2019, 04:04 AM
I change the brake fluid at the beginning of every season. I track the car occasionally and after having experienced boiling fluid once, I decided to not do it ever again.
05-27-2019, 04:54 AM
Overkill for street cars but cheap and easy to do if you have a power bleeder.
__________________________
'58 356A coupe, just a driver
05-28-2019, 04:31 PM
I agree, two years is overkill for a street driven car but its not that expensive if you can DIY it.
I race my Spec Boxster and even then I only change the brake fluid once or twice per year.
05-29-2019, 12:27 AM
the "p car"?
05-29-2019, 02:00 AM
What you should be doing is monitoring the fluid's moisture content and changing it when it starts to go up; OTC makes a $20 tool that will tell you when it needs to be changed.
05-29-2019, 06:44 AM
[QUOTE=Burg Boxster;596178]yes every 2yrs... brake fluid is hygroscopic.
No 3 times a year!
05-29-2019, 08:10 AM
Great advice PA; where is the OTC tool available?
05-29-2019, 10:20 AM
Anywhere OTC tools are sold, Amazon carries it:
05-29-2019, 04:12 PM
On order from Amazon chose the Dot4 tool
05-29-2019, 07:19 PM
Damn Yankee
Thanks for the tip, JFP. Never knew these devices existed. And thanks for all the expert advice and insights you've contributed over the years.
And I'm not "just sayin....."
TO
06-03-2019, 02:55 PM
This tool may save you time and money. It's been 2 years since I changed/flushed the Brake Fluid. I drive the P car in Summer/Fall. The brake fluid tester shows less than 1% water in the brake fluid and is OK. Without this tester, I would've flushed the brake fluid as recommended by the manual.
06-04-2019, 01:50 AM
That's exactly why we use them in the shop.
06-04-2019, 04:12 PM
Neat device but it won't tell if air bubbles trapped in the line? I guess you must feel that.
After 3 years/ 30K miles of ownership I finally got to flush and bleed the lines with Motul 600 and was amazed how easy to lock up front tires now!
06-04-2019, 05:39 PM
I was amazed how easy to lock up front tires now!
Boxtard, you may want to bleed the rear axle again.. :-)
06-05-2019, 03:07 PM
I used 1.5L of fluid for pressure bleeding and pretty confident that rear are fine.
In fact I thought by design brake force is biased to front so that rear never lock up before front...
