Old 04-28-2019, 09:19 AM   #1
truegearhead's Avatar
What Spark Plugs are you running?
Is the factory plug the one to go for or is there a better one on the market?
Cheers,
Stu
1997 Boxster 4.2L Audi V8 Bi-Turbo
2003 911 C2
NASA HPDE Instructor
truegearhead is offline   Reply With Quote
Old 04-28-2019, 12:53 PM   #2
Ciao's Avatar
Better is relevant. Factory works fine unless you have pimped out the engine.
5280 Cruising @High Altitude
Seal Gray & K&N Filter
Old 04-28-2019, 12:56 PM   #3
Need For Speed
KRAM36's Avatar
I'm using NGK 94279 FR6AHX-S Ruthenium HX plugs. So far they have been great plugs.
2003 Boxster S
Old 04-28-2019, 10:35 PM   #4
Beru fitted last time I changed mine. Cheap and correct so you can't go wrong.
jonogt6 is offline   Reply With Quote
Old 04-29-2019, 04:26 PM   #5
I've used NGK, Beru, Porsche, and Bosch. All have worked fine and I couldn't tell any difference between them.
Old 04-30-2019, 06:34 AM   #6
BYprodriver's Avatar
I buy the cheapest Iridium name brand plugs I see. They last longer.
Old 05-03-2019, 10:48 AM   #7
BOOTLEG's Avatar
Called a Pelican "Porsche Specialist" for guidance on the ~10 choices of plugs listed for my 3.2L engine. She asked if I tracked my car which would affect the proper plug choice. Neither of us could determine exactly how the internal combustion process would change with track vs. street asphalt conditions. She thought the gap might be different - etc...
It would seem the TStat, H2O pump, fans, ECU would all operate the same. Commentary from those with facts???
BOOTLEG is offline   Reply With Quote
