Old 04-24-2019, 09:57 PM   #1
elgyqc's Avatar
IMS flange nut and bolt torques?
Does anyone know the proper torque values for reinstalling the IMS flange (the 3 bolts that hold the flange on and the center nut)?
Grant
elgyqc is offline   Reply With Quote
Old 04-24-2019, 10:36 PM   #2
Need For Speed
KRAM36's Avatar
The torque is 10 nm (7 ft-lb) on those bolts.
2003 Boxster S
Old 04-25-2019, 06:16 AM   #3
elgyqc's Avatar
Thanks.
And for the center nut? Pelicans says 24 ft/lb (but it is not clear to me if that is for the original flange and center bolt or for the LN kit which has a stronger center bolt), elsewhere I saw 12 nm. Provisionally I torqued to about 15 ft/lb which seems about right as long as the original bolt is not too fragile.
Grant
Old 04-25-2019, 06:34 AM   #4
Need For Speed
KRAM36's Avatar
Originally Posted by elgyqc View Post
Thanks.
IMS Solution manual says.
Center IMS flange nut torque must be at least 12 ft/ lb,but not to exceed 20 ft/lb
2003 Boxster S
