Old 03-11-2019, 01:32 PM   #1
truegearhead's Avatar
Follow up question, does anyone know what pressure the relieve valve opens?
1997 Boxster 4.2L Audi V8 Bi-Turbo
2003 911 C2
NASA HPDE Instructor
truegearhead is offline   Reply With Quote
Old 03-11-2019, 03:16 PM   #2
jsceash's Avatar
I'm not certain where they are set, they are regulated with a thermostatic spring. I have 2 oil gauges one for the sump and one on the passenger head port. I get 100 PSI cold on the sump and 80 PSI cold on the head. Warm I get 80 PSI and 70. The pressure relief should not pop those caps, unless you got carried away with sealant there is a relief port on the cap journal.
Old 03-11-2019, 06:03 PM   #3
jaykay's Avatar
There is a 997 oil pump pressure regulator upgrade that can be done. IIRC it regulates oil pressure on start up. Just search on here and you should find it....I can pull out if you don’t
It maybe that your plunger is sticking if the pressure is over spec. I have yet to change mine so this is all parroted info. It may fix your issue though
986 00S
