Old 09-18-2006, 12:47 AM   #1
Engine vibration
Yeh sorry forgot the important info:- 2001 Boxster S, 68,000 KM'S, 18" GT3 rims, factory aero kit, Porsche super sound exhaust, you could be right about the mounts, when you they usually give up?
lewbo is offline   Reply With Quote
Old 09-18-2006, 10:40 AM   #2
Post
I think its the engine mount. I own a 98 Box and the mount went bad, while driving or shifting I could sometimes feel the pedals move and vibrate. The Engine Mount isn't that expensive, and it's not that difficult of a job to do. If you plan on doing it yourself which would save you a lot of cash, bling!!!, medallions, or whatever you want to call it, make sure to tighten bolts to specified torque. Its not just a screwing it until it doesn't move anymore!!!. Also make sure you get the new type mount, it has a metal plate at opposite ends. The part number is 986 375 023 05 its called Motor console on the PET program.
BoxsterRS is offline   Reply With Quote
Old 09-18-2006, 12:26 PM   #3
Send a message via MSN to CJ_Boxster
Could be your engine mount BUT its more likely that your flywheel is warped, when they get warped they will jitter or chatter when engauging until they are fully engauged....you can either machine it smooth or buy a new one....change your rms while your at it.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
