Old 01-11-2019, 03:07 PM   #1
Artist, 986S tinkerer
NewArt's Avatar
Found my m96... a bit iffy
Having missed the RND rebuilt (by minutes, I’m sure) offered by LN Engineering recently, I’ve decided to go out on a limb and have purchased a 3.6 which runs but has a knock. Since I only paid $1500 CAD for it (about $1100 USD), I am willing to put a fair bit of change into the repair/rebuild. I suspect cylinder scoring but I’ll only know after the teardown. (Oh yay, I get to produce another YouTube video for my channel!).
I’ll keep you posted.
Old 01-11-2019, 04:11 PM   #2
Ciao's Avatar
Best of Luck NewArt! Look forward to your next youtube; they've been great.
5280 Cruising @High Altitude
Seal Gray & K&N Filter
Old 01-11-2019, 05:17 PM   #3
steved0x's Avatar
I bet that 3.6 will add some kick!
Old 01-11-2019, 06:26 PM   #4
elgyqc's Avatar
Congrats. Looking forward to this.
If you are looking for some preparatory reading check this...
https://rennlist.com/forums/rennlist-canada/706081-dragged-home-one-of-these.html
Grant
Old 01-11-2019, 06:28 PM   #5
elgyqc's Avatar
Followed by this...
Dragged home one of these engine repair project #2 - Reutterwerk Forums
Grant
Old 01-12-2019, 07:47 AM   #6
NewArt's Avatar
Thanks for the links Grant. I’ve been reading a lot about the rebuild process. I’m a little nervous but how hard can it be, eh?
Old 01-12-2019, 07:50 AM   #7
NewArt's Avatar
Especially if I get it punched out to 3.8 !
Old 01-12-2019, 12:40 PM   #8
It probably takes about five to six months to have LN install Nickies, as I am finding out. Hartech is a company that will replace just 1 scored cylinder or one bank, if you only need that and want to stay at 3.6 liters. Dayton Sleeves makes sleeves for the M96/M97 3.6 that are ductile steel or cast iron, and there is another company who installs cast iron cylinder sleeves in the M96/M97 engines whose name escapes me. I went with the Nickies, there is some controversy over cast iron/ductile steel cylinder liners for these engines. Looking at the price for OEM Porsche piston rings, the cost of the Nickies didn't seem so horrible.
Old 01-12-2019, 12:54 PM   #9
NewArt's Avatar
Wow, that’s a long wait! I will definitely look into other possibilities. I don’t mind staying at 3.6.
Old 01-12-2019, 02:39 PM   #10
They use one of the best platers in the country for the cylinder bores, and that plater does lots of engines for cars, motorcycles and snowmobiles. The plating is done after the block is machined and the cylinders are inserted. Hope you're lucky and you don't need it!
Old 01-13-2019, 08:16 PM   #11
halo777's Avatar
Nice find! Good luck with the rebuild. Ill be following your progress for sure
halo777 is offline   Reply With Quote
Old 01-14-2019, 11:44 AM   #12
NewArt's Avatar
Pulled the filter. Some small metal bits were hiding in the pleats. I expected as much.
LN said 6 or so weeks turnaround for the sleeves and nickies if I send them the block halves.
Old 01-14-2019, 05:05 PM   #13
I hope they’re right! Last August my estimate was at least 8 weeks!
