Old 09-27-2018, 07:20 AM   #1
both times I've done this, I needed to use bolts to draw the gearbox onto the motor, but basically with my hand on the head of the ratchet to ensure I wasn't running into undue resistance.
Old 09-27-2018, 08:35 AM   #2
Should not be necessary, and is also rather dangerous. Once lined up, the box should just slide right up to the back of the engine with a pronounced "thump".
Old 09-27-2018, 06:59 PM   #3
I agree JFP but unfortunately its didn't want to.
I ended up putting another bolt in the top and tightened each one incrementally until it was flush.
Whilst still up on jack stands I started her up (no exhaust) & made sure all gears could be selected. All good.
http://i13.tinypic.com/49ied5h.jpg
2000 2.7 Boxster
aussieboxy is offline   Reply With Quote
Old 09-27-2018, 07:30 PM   #4
Who's askin'?
maytag's Avatar
I did this too. And I was so uneasy with it that I fretted all night long. the next day I removed the g-box again, looked everything over, looked fine, put it back up in and THAT time it seated just as JFP has described.
Like you, I've done dozens of clutches in my life, and had never had that problem before.
Old 09-28-2018, 08:24 AM   #5
A few times in the past, when the gearbox simply does not want to move past the last inch, I noticed that rotating the crank slowly helps to synchronize the clutch disk with the transmission shaft..
When you are under there sweating and cursing, you will try everything ...LOL
Old 09-28-2018, 09:10 AM   #6
Actually, because you are already at the gearbox, rotating one shaft flange while holding the other (in any gear) will accomplish the same thing.
Old 10-05-2018, 10:42 PM   #7
Murphy's Law
Yeh tried that too.
Ok. Whilst the greabox was in, bolted flush & before refitting anything I started her up, & whilst in neutral I whipped on the handbrake to ensure the was no sticking (ie no effect on revs) & then handbrake off & through the gears each time engaging clutch & checking for wheel speed....all good.
So put everything back on & back on the deck the went to reverse out of the garage & as I pushed the clutch it there was a bit of a clunk & the pedal stayed down & no clutch engagement. F*&%K!!!
Back up she goes, pulled slave cylinder out which is a touch more difficult with all the undercarriage & exhaust back in, & the slave cylinder has come apart.
Ok to the matter at hand. When I pulled the salve cylinder off all the fluid had leaked out. What's the best way to bleed the clutch without a pressure bleeder & do I need to bleed the brakes as well because they use the same brake fluid revsiviour?
2000 2.7 Boxster
