Old 09-04-2018, 10:42 PM   #1
Clutch Alignment Tool
Replacing the clutch in my 00 Boxster after 228,000Km.
In the past I have used a home made tool that I made from a broom handle, but want to ensure I get it right 1st time as it looks like a PITA to the the trans back in.
Any hints or idea's would be appreciated.
http://i13.tinypic.com/49ied5h.jpg
2000 2.7 Boxster
aussieboxy is offline   Reply With Quote
Old 09-04-2018, 11:07 PM   #2
Clutch kit should come with one...
If not, a big wooden dowel with the end turned down to fit the pilot bearing might work.
Old 09-05-2018, 04:02 AM   #3
Who's askin'?
maytag's Avatar
If your car is a 5-spd, send me your address, I'll send you the tool. (The 5 spd is a different diameter input shaft than the 6 spd. Ask me how I know.... grrr)
Old 09-05-2018, 03:11 PM   #4
They are $9
https://www.pelicanparts.com/catalog/SuperCat/1046/POR_1046_TCLUTC_pg2.htm#item11
__________________________
'58 356A coupe, just a driver
356Guy is offline   Reply With Quote
Old 09-06-2018, 04:52 PM   #5
Which one is for the Boxster & which for the Boxster S?
Clutch Alignment Tool,, (Spline count = 23; Pilot diameter = 14.9 mm; Spline diameter = 23.8 mm)
Clutch Alignment Tool,, (Spline count = 23; Pilot diameter = 14.9 mm; Spline diameter = 25.4 mm)
2000 2.7 Boxster
Old 09-06-2018, 05:37 PM   #6
Who's askin'?
maytag's Avatar
The larger diameter is the S. (I didn't measure it, so can't confirm the 25.4mm, but the clutch tool for the 5-spd fits snugly in the 5-spd clutch, whereas it's all loosey-goosey in the 6-spd clutch. )
Old 09-06-2018, 07:03 PM   #7
Thanks mate
2000 2.7 Boxster
Old 09-06-2018, 04:49 PM   #8
Yes it's a 5 speed but I'm in Australia
2000 2.7 Boxster
