Old 09-03-2018, 04:30 PM   #1
2002 3.2 oil pressure oddities
Driving home from a bit of a road trip today, I was cruising down the freeway at about 3200rpms and noticed my oil pressure gauge doing odd things. Generally, the pressure shows normal around 45-50 PSI. However, it would randomly spike up (once tapped 8 bar) and then settle and be fine. Oil pressure at idle is normal, car runs fine. It is ENTIRELY possible it has done this since I installed the gauge, but not noticed it. I just happened to see it happen this time. 996 sender is relatively new (1.5k miles). Prob not an issue at all, just wondered if anyone had any thoughts.
Old 09-03-2018, 06:24 PM   #2
BYprodriver's Avatar
Those sending units are very unreliable.
Old 09-05-2018, 07:13 AM   #3
Any suggestion of an "upgrade"?
Old 09-05-2018, 10:00 AM   #4
When i rebuilt my engine I installed a small VDO gauge & their sending unit in the opposite cam cover by tapping the block off plug with 1/8th" pipe threads
Old 09-05-2018, 12:49 PM   #5
AZ986S's Avatar
That's a smart idea.
I ended up just getting the 14x1.5 VDO sender.
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
Old 09-05-2018, 01:56 PM   #6
The Radium King's Avatar
996 sender is a rebranded vdo unit, yes?
Old 09-05-2018, 09:45 PM   #7
That’s what I thought too. Perhaps the better solution is to maintain the single dummy light sender in the stock location and place a dedicated pressure sender on the other side. Is it the pressure sender itself that is troublesome, or the dual unit in particular?
I have a VDO guage...
