Old 08-10-2018, 09:00 AM   #1
Who's askin'?
maytag's Avatar
Mismatch in Trans Mount Bolts & Holes
Hey y'all:
In removing my trans, I discovered soemthingt hat seems odd to me, and I'd like to hear from y'all who know.
The trans mounts are held into their carrier (and the chassis) with 2 bolts each, held by a nut on the bottom. I don't have them in my hand, but they're probably an M10 thread. Oddly, they fit snugly into the holes in the mount, but the holes on the carrier attached to the chassis that the bolts drop into are substantially larger. This means that it's quite possible (probable?) that they move around in that hole.
Is this correct? should there be a bushing of some sort? do I have a mismatch of something?
Have I even described this adequately? haha
TIA
Old 08-10-2018, 09:20 AM   #2
911monty's Avatar
Oh you again? Are you talking about the 2 bolts that pass thru the rubber insert? If so I don't recall any loose fit to that degree. I upgraded mine to the 987 style with the new isolators and everything fit precisely, there was no room for movement there.
OR you're talking about where the mount attaches to the sub frame? If this is the case (and I think it is) then this is a loose fit although it is tighter than where the four studs pass through the sub frame, lots of movement there.
Old 08-10-2018, 02:17 PM   #3
Who's askin'?
maytag's Avatar
If i did this right, then I just attached an image I took from Google, and added yellow arrows to show the location of the bolt I'm describing.
Fingers crossed that I did this right, haha!
Old 08-10-2018, 02:56 PM   #4
jsceash's Avatar
Those Bolts are smaller in Diameter than the holes. I believe 8mm
Old 08-10-2018, 06:43 PM   #5
Who's askin'?
maytag's Avatar
excellent.
WHY? :-)
Old 08-16-2018, 02:45 PM   #6
Who's askin'?
maytag's Avatar
excellent.
WHY? :-)
Anybody? Anyone know WHY there's this mismatch in the hardware?
Old 08-16-2018, 08:49 PM   #7
Racer Boy
Racer Boy's Avatar
It one of the mysteries of German engineering!
