Old 08-10-2018, 10:20 AM   #2
911monty
911monty's Avatar
Oh you again? Are you talking about the 2 bolts that pass thru the rubber insert? If so I don't recall any loose fit to that degree. I upgraded mine to the 987 style with the new isolators and everything fit precisely, there was no room for movement there.
OR you're talking about where the mount attaches to the sub frame? If this is the case (and I think it is) then this is a loose fit although it is tighter than where the four studs pass through the sub frame, lots of movement there.
