Old 06-24-2018, 09:53 AM   #1
Engine Swap Options
Hi All, I poked around the forums and couldn't find an answer to this question:
I have a 2004 Boxster S that I will be doing an engine swap on (apparent crankshaft failure). I know from Wayne's guide on Pelican Parts that it will take any later Boxster/Cayman engine. However, is that ONLY through MY 2008 donors?
ie, can I put a 987.2 3.4L engine (MA121) with DFI in or is it limited to most recent M97 engine ie M97.2x.
And when I say put in, I mean in about as straight forward a fashion as a swap to the M96 engines.
Thanks!
Plastikos is offline   Reply With Quote
Old 06-26-2018, 11:36 AM   #2
Super Moderator
I see that you added a Comment just below the tech article - someone should get back to you shortly. I also found the below thread - seems that the MA could be a bit problematic.
986 to 987 engine swap
Dmitry at Pelican Parts is offline   Reply With Quote
Old 06-27-2018, 08:08 AM   #3
BYprodriver's Avatar
Thanks!
Any DFI engine requires a extremely high pressure fuel pump which is very expensive. Safely installing it & other require plumbing will require alot of modification.
