Old 05-20-2018, 02:19 PM   #3
Originally Posted by scott17201 View Post
I replaced my MAF sensors with 2 new ones from carparts.com and check engine light came back on again same code P0102. Could it still be a bad MAF sensor and just replace it with a bosch?
P0102 indicates that you either have a wiring break or short to ground. An new MAF will not fix this, you need to find the wiring issue and fix it.
