Old 04-22-2018, 02:16 PM   #1
CEL after winter storage. Low mileage 986
Started my low mileage base Boxster after winter hibernation.
CEL came on but running seemed ok.
Thinking a short ride would clear it I went out gently. After a minute or so the CEL began blinking and engine became noticeably tougher.
Thoughts?
Thanks, Pete
PWilson45 is offline   Reply With Quote
Old 04-22-2018, 02:21 PM   #2
What codes did you get when you scanned it?
Old 04-22-2018, 02:24 PM   #3
Unfortunately my scan too is at another location.
Old 04-22-2018, 03:14 PM   #4
Maybe cracked coil packs taking on moisture during storage and misfiring, though that is just a wild guess without codes.
Old 04-22-2018, 04:52 PM   #5
Porsche "Purist"
Paul's Avatar
IME a blinking CEL light means don't drive unless you want to do additional damage.
1987 924S. 2002 996TT. PST-2
Old 04-22-2018, 07:03 PM   #6
I think blinking CEL is indicating misfiring that could destroy CAT.
Old 04-23-2018, 06:58 AM   #7
flete25's Avatar
check coils and spark plugs
flete25 is offline   Reply With Quote
Old 04-23-2018, 04:14 PM   #8
AZ986S's Avatar
Had something similar happen to me last year. Ran like crap, CEL blinking. Towed it home. Ended up being the hydraulic chain tensionners. I had all 3 replaced and all is good. But you definitely want to pull the codes and consider other possibilities like coil packs, O2 sensor, MAF sensor or engine timing sensors.
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
Old 04-26-2018, 04:26 AM   #9
Beginner
Jamesp's Avatar
The year makes a difference. On my 03 I had a blinking CEL due to misfire because the electrical connector fell off the variocam. Hooking the variocam back up solved the problem.
2003 S manual
