Old 04-12-2018, 11:07 AM   #1
Coaster's Avatar
Camber adjustment?
2003 lowered S. Daily driver - no track. Tail was squirmy in the rain due to low tire tread. I replaced tires and had the independent shop do an alignment. They say the lowered car is limited so they picked getting rear toe at 0 and took more camber. Do I need rear adj toe links? If so, what are the recommendations to research?
Front
L -1.1 Camber R -0.8 (spec -0.4 to 0.6)
L 8.4 Caster R 8.6 (spec 7.5 to 8.5)
L .04 Toe R .02 (spec 0.00 to 0.08)
Back
L -2.8 Camber R -3.0 (spec -1.8 to -0.8)
L 0.00 Toe R 0.00 (spec 0.00 to 0.17)
2003 S, 6 Speed, PCM, PSM, Bose, Litronics with washers, on its' second LN IMSB, comfort top, UDP, 987 engine mount, 997 RMS, Koni Sport Shocks, H&R springs, Techno brace, comfort blinkers, nin8six windscreen, particlewave light up cubby
Coaster is offline   Reply With Quote
