Old 04-08-2018, 02:23 PM   #1
Weird humming, RPM drop and Stalling
Hello everybody.
I have been having a very weird issue with my car lately. When driving, assuming that I at least drive for 30-40 minutes, my car begins to make a humming noise near the front right side wheel (near the gas cap). This typically begins to happen when the car is roughly between 180-200 degrees F.
After this hum, the RPM drops. In some occasions it simply stalls but the car remains on. In other occasions, the car drops RPM significantly when idle and turns off leaving me stranded or revving the engine when I'm stopped so it doesn't turn off.
Has anyone had the same issue? If so, did you manage to fix it?
PorscheKd986 is offline   Reply With Quote
