Old 04-05-2018, 03:26 AM   #1
IMS bearing pulled
In short, I have pulled my IMS bearing after hearing a knocking sound at 1/2 engine speed. The bearing is perfectly okay, I will replace etc I don't want to assemble everything back to gather and find I still have the problem, any suggestions? Im lost at this point.
Doing all the work DIY. Its a double row bearing FYI. 986 S 2000 MY.
thanks,
Robert
de-snorkeled, clear lights, sports exhaust, zeintec hard top, zein wing, B&M short shifter, DesignTek lowering springs, DesignTek carbon fibre strut brace front and rear, 18'' carerra 5 spokes, semi slick tyres, entire soft top delete, engine cover delete,red console,L&N deep sump, volo performance chip, raptor shift light, de-cat'ed, OEM GT3 bucket seats.
sickbananas is offline   Reply With Quote
Old 04-05-2018, 06:21 AM   #2
If it really is at 1/2 engine speed its probably a hydraulic lifter that's failing. The only parts that run at 1/2 engine speed are the cams and the fuel injectors.
1941 Dodge Luxury Liner Coupe
Old 04-05-2018, 03:34 PM   #3
thanks,
Robert
Why did you pull the IMS prior to doing other diagnostics? Unfortunately with the IMS craze, it seems like everything that can go wrong with these motors is the IMS default... On the good side, you got it done. On the not so good side, you still have to put it all back together and figure out what is actually going on. Any codes being thrown?
Old 04-05-2018, 05:20 PM   #4
And don't reuse the bearing you pulled. You damage it by removing it.
