Old 01-27-2018, 09:18 AM   #1
Rich
is engine 360deg off?
I had both sets of my cam shafts off the car at one time. When cylinder one is TDC compression both cam index marks face in and the Porsche tool 9624 doesn't fit in. rotate 360 and both index marks are facing out but 1 is not on compression and tool fits. is that correct? or did i screw something up? i took my compression tester and the firing order was 1-6-2-4-3-5 as it should be.
Rich XTR is offline   Reply With Quote
