Old 01-26-2018, 03:33 PM   #1
Oldcarguy's Avatar
New Porsche AOS reading 5.3 WC - opinions??
After replacing my ver.00 AOS with a new Porsche Genuine AOS ver.01 I was disappointed to find that the new AOS was still reading between 6.21 and 7.28 inWC. Pretty much what the old one was reading. Here’s my original thread:
If it ain’t broke, don’t fix it??
Not trusting my $35 manometer, I ordered a Fieldpiece manometer. With the Fieldpiece my new AOS is reading in the high fives cold and 5.32 - 5.41 warm. The cheap manometer is off by ~1 inWC
JFP indicated that anything above 5.0 warm is candidate for replacement. The Pelican article says 4-7 is ok. I think I’m going to call it good at 5.32, watching for symptoms and monitoring WC regularly. I really don’t want to go back in and risk breaking the AOS plastic squeeze clamps unless I really need to.
What do you guys think???
Rgds, Fred
Old 01-26-2018, 03:40 PM   #2
Originally Posted by Oldcarguy View Post
After replacing my ver.00 AOS with a new Porsche Genuine AOS ver.01 I was disappointed to find that the new AOS was still reading between 6.21 and 7.28 WC. Pretty much what the old one was reading. Here’s my original thread:
Not trusting my $35 manometer, I ordered a Fieldpiece manometer. With the Fieldpiece my new AOS is reading in the high fives cold and 5.32 - 5.41 warm. The cheap manometer is off by ~1WC
JPF indicated that anything above 5.0 warm is candidate for replacement. The Pelican article says 4-7 is ok. I think I’m going to call it good at 5.32, watching for symptoms and monitoring WC regularly. I really don’t want to go back in and risk breaking the AOS plastic squeeze clamps unless I really need to.
4-7 is OK on a cold start, but 5 is our limit warmed up. Yours is marginal, so I would leave it alone, but check it regularly to see if starts going up.
Nice manometer by-the-by.....
Old 01-26-2018, 03:54 PM   #3
Oldcarguy's Avatar
Hi JFP, thanks for the quick response. Good news! I’ll leave it and monitor. At least I’m within spec for the cold start and now I have the latest version.
The Fieldpiece is awesome, thanks. I know better than to try and cheap out on important equipment but I slip sometimes.
Rgds, Fred
Old 04-28-2018, 02:54 PM   #4
Oldcarguy's Avatar
Quick update. I finally checked the vacuum with the car fully warmed up. As JFP advised, it’s just like the cam variance - only check it when the car is truly at operating temp after a good run. My new AOS is well in spec:
Done!
Rgds, Fred
Old 04-30-2018, 08:21 AM   #5
I have owned 996’s and a 997, but I am not familiar with this AOS test.
I am having a PPI done next week on a 986. Is this test routinely done as part of a PPI? If not, do I just request an AOS manometer test?
Thanks.
2004 996 40th Anniversary
VeryRed997 is offline   Reply With Quote
Old 04-30-2018, 08:24 AM   #6
Thanks.
It should be, but it never hurts to ask. We check the AOS on every car passing through the shop, regardless what it is in for. Only takes a min.
Old 04-30-2018, 08:27 AM   #7
Many thanks!
Old 04-30-2018, 10:27 PM   #8
What’s the best way to connect the manometer to gain the reading?
Old 05-01-2018, 02:25 AM   #9
An old oil fill cap with a fitting mounted to it.
Old 05-01-2018, 05:11 AM   #10
Besides the AOS, what can the Fieldpiece manometer help you diagnose on a vehicle?
Woody
Old 05-01-2018, 08:24 AM   #11
A digital manometer can read both pressure and vacuum very accurately, so anywhere you would be testing either. Its major advantage is in the fact that it can read very low levels of either.
Old 05-01-2018, 11:41 AM   #12
Thanks! That's what I figured!
Old 03-03-2019, 10:04 AM   #13
Oldcarguy's Avatar
-deleted post, wrong message thread-
Rgds, Fred
