New Porsche AOS reading 5.3 WC - opinions??
After replacing my ver.00 AOS with a new Porsche Genuine AOS ver.01 I was disappointed to find that the new AOS was still reading between 6.21 and 7.28 inWC. Pretty much what the old one was reading. Here’s my original thread:
http://986forum.com/forums/performance-technical-chat/69866-if-ain%92t-broke-don%92t-fix.html Not trusting my $35 manometer, I ordered a Fieldpiece manometer. With the Fieldpiece my new AOS is reading in the high fives cold and 5.32 - 5.41 warm. The cheap manometer is off by ~1 inWC https://uploads.tapatalk-cdn.com/201...d9f2701fef.jpg JFP indicated that anything above 5.0 warm is candidate for replacement. The Pelican article says 4-7 is ok. I think I’m going to call it good at 5.32, watching for symptoms and monitoring WC regularly. I really don’t want to go back in and risk breaking the AOS plastic squeeze clamps unless I really need to. What do you guys think??? Sent from my iPad using Tapatalk |
Nice manometer by-the-by..... |
The Fieldpiece is awesome, thanks. I know better than to try and cheap out on important equipment but I slip sometimes. |
Quick update. I finally checked the vacuum with the car fully warmed up. As JFP advised, it’s just like the cam variance - only check it when the car is truly at operating temp after a good run. My new AOS is well in spec:
https://uploads.tapatalk-cdn.com/201...511d3a9091.jpg Done! Sent from my iPad using Tapatalk |
I have owned 996’s and a 997, but I am not familiar with this AOS test.
I am having a PPI done next week on a 986. Is this test routinely done as part of a PPI? If not, do I just request an AOS manometer test? Thanks. |
Many thanks!
What’s the best way to connect the manometer to gain the reading?
Besides the AOS, what can the Fieldpiece manometer help you diagnose on a vehicle?
-deleted post, wrong message thread-
| All times are GMT -8. The time now is 02:57 AM. |
