Old 12-20-2017, 06:45 AM   #1
AZ986S's Avatar
New wheels
I loaned the Boxster to my GF last week and she enjoyed it immensely until... well let's just say I need a new rear suspension, wheels and tires Thankfully she is fine and there doesn't appear to be any body damage or anything to the front wheels (so far).
So I'm having the car done at my usual trusted Indie (McIlvain Motors) here in Tempe, AZ. Will need the following:
On both rears:
*Lower control arms
*Trailing arms
*Toe control arms
*New wheels
On right rear:
*New axle
On all 4:
*New tires
I am wondering if the wheel bearings or sub-frame could be affected by those impacts to the rear wheels... The transaxle appears to be OK. I will have Wheel Specialists in Tempe look at all 4 wheels and tell me which ones are bent, but I already know both rears are. Then I have to figure out what I want to do for wheels. Do I just replace the 2 rear with the 18in Turbo Twists that I have? These are for street only as I have a set of dedicated track wheels.
I've always liked the Cayman 987.1 wheels... (courtesy of a fellow forum member)
Or the Carrera lights...
Are these true OEM?
Porsche Cayman 2007 18" OEM Front Wheel Rim
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
