Old 12-13-2017, 01:41 PM   #1
Relocate battery
I just purchased a Odyssey PC925 to reduce weight. When I´m about to put the new battery in I cant help but thinking of how high the battery box is located. The PC925 is considerably lighter than the original, but is still a respectable weight. Wouldn´t it be great to place it at the bottom of the frunk to lower COG... Hmmm cant hurt.
So I start looking at how to fasten it and how to relocate the wires.. Strange thing, I found absolutely no example of others on the forums performing this operation.. Is it just me?
Old 12-13-2017, 02:45 PM   #2
So what would you give up. Trunk space? The spare tire? A simple connection? Dangling wires?
Old 12-13-2017, 02:57 PM   #3
IT is just you!!!! ;-)
Make so little difference in CG and lots of headaches.
2003Boxster
1973 Carreras RS tribute
2000 Saab Aero wagon stick
1990 Chevrolet pu pre runner
boxfix is offline   Reply With Quote
Old 12-13-2017, 05:02 PM   #4
1999 base
Meir's Avatar
Extending the battery wires is always a bad idea.
You will interduce unnecessary resistance to the power distribution.
Old 12-13-2017, 05:28 PM   #5
2003 S, Arctic Silver, M6
paulofto's Avatar
Had the Porsche engineers thought that the battery should reside lower in the body they would have done it. A lot of work for likely no improvement.
Old 12-13-2017, 07:47 PM   #6
Topless's Avatar
It's just you.
The battery location was carefully chosen on the centerline of the car to protect it in an impact so the car doesn't catch fire with you in it. The rest of the car will be sacrificed yet the battery, fuel tank, and passenger compartment are well protected.
Old 12-14-2017, 04:32 AM   #7
Spec boxster's have to keep the battery in the stock location but almost every other type of boxster or 996 race car I've seen moves it to a lower position in the car. The optimal place on a boxster is in the passenger foot well from what I've heard. A lot of them move it down in the frunk. That's where I moved mine and I put it right in front of the spare tire. You're only extending the cables 2 feet at best. That won't cause electrical issues. Heck, people have been relocating batteries to the trunk for decades. Many many vehicles have the battery located in a very vulnerable spot with only a little bit of sheet metal protecting it. I've bought quite a few cars where the battery was crushed in the accident. No fire. If you don't believe me, go on copart.com and you'll see thousands of cars/trucks with crushed batteries and no fire
Woody
Old 12-15-2017, 06:15 AM   #8
Wow, great response!
Thanks all.. I´m not to concerned regarding the safety aspect, and if I´ll do it it will need to be a very neat installation, no cheesy Cables hanging around.. I guess it all comes down to wether I should prioritize this before all other stuff I plan to do on the car this Winter. Still if someone has done it, it would be very nice to se some pics or get some hints.
If I go ahead I´ll show & tell :-)
Edit: To answer a previous question: I have already given up the spare and replaced it with a small compressor/repair kit.
A lot of effort for very Little improvement is my trademark ;-)
Old 12-15-2017, 10:19 AM   #9
If you go on here Woody's build thread with google chrome you can see some pictures of my install.
Woody
Old 12-16-2017, 08:02 AM   #10
BYprodriver's Avatar
I have a aluminum sheet mount for a Odessey 925 for sale if interested in buying
Old 12-17-2017, 07:38 AM   #11
Thanks! However I live in Sweden so I guess its a bit far :-)
Old 12-17-2017, 05:33 AM   #12
You went to the trouble of relocating the battery and you still have a spare tire in the trunk ?
Old 12-17-2017, 02:57 PM   #13
It only is about thirty minutes of work to relocate the battery. It's still a street car and the spare comes out at the track
Woody
Old 12-15-2017, 10:28 AM   #14
Maybe you install that lighter battery you got and see if it makes appreciable difference to you. If not, probably you won't notice much difference moving it down to the frunk floor and you can prioritize other things.
I like the way it is installed, protected from impat and weather. With 914 they installed it in the engine bay half exposed to the environment so it spits acid right over the longitudinal frame to corrode it.
Old 12-15-2017, 11:38 AM   #15
Rennzenn
j.fro's Avatar
My solution. Of course, I've also dumped all of the trunk interior, etc. Part off the goal was to try to balance out the brake booster. The car is naturally driver side heavy.
Rennzenn
Jfro@rennzenn.com
Old 12-16-2017, 02:18 AM   #16
BOOTLEG's Avatar
Nice!
Think I will do this.
BOOTLEG is offline   Reply With Quote
Old 12-16-2017, 04:30 AM   #17
If you look at the bottom of the frunk in J.Fro's picture. Those two rubber plugs come out easily and make a great vent for the battery tube
Woody
Old 12-27-2017, 04:27 PM   #18
Talk about fast hands... check out this 914, similar weight distribution, on ice...
https://youtu.be/Zcgu4xedAjs
