11-19-2017, 06:25 AM
Beginner
Complete suspension replacement
I'm going to replace my entire suspension. At 15 years old and over 140,000 miles I want to replace everything.
Driving over a rough road the car sounds like a tin can filled with loose rocks. The rear tires are also wearing out fast and unevenly.
The car is a daily driver.
I'm thinking Bilstein B6.
Also - if anyone has a list of all of the parts that should be replaced I'd appreciate it so I don't end up missing something.
Thoughts?
2003 S manual
11-19-2017, 06:33 AM
Thoughts?
I’m doing the same thing right now on my 97 with over 234k miles. Bilstein B8 struts, H&R springs, drop links, shock mounts, snubbers, dust boots, strut bearings, and rear tuning forks. DIY except alignment which will be done by my independent shop(ProTech Motorsports).
11-20-2017, 10:24 AM
I️ am doing the same on my 98 w/102K miles. What is the consensus on replacing inner tie rods?
11-20-2017, 11:15 AM
Don't forget your bushings. I think from the factory you can only get the sta-bar bushings, but there are poly bushings from https://powerflexusa.com/boxster1997-2004.aspx if you want to go that route. Will make your car more responsive and might be a bit cheaper than getting new links. However, it does involve some really annoying DIY
Also remember the motor and tranny mounts
11-22-2017, 03:45 PM
Beginner
First off, thanks for all the responses. But then again, hey all you 986 suspension gurus, please weigh in! I'm going for a complete suspension retrofit and need your help! If you were going to replace EVERYTHING that needed to be replaced to improve handling after 140K miles, what would you do?
2003 S manual
11-22-2017, 04:27 PM
This a very wide open request. stock numbers and parts look like this.
Two - 986 331 043 07 -
Control Arm Links (Track Arm)
One for Rear Left Driver Side
One for Rear Right Passenger Side
Two - 997 331 045 04 -
Control Arm Links
One for Rear Left Lower Rearward
One for Rear Right Lower Rearward
Four - 996 341 053 17 -
Control Arms
One for Front Left Lower
One for Front Right Lower
Two - 996 341 043 06 -
Control Arm Links
Drop links
2 Porsche part# 996 343 069 04
2 part# 996 343 070 04.
11-24-2017, 11:01 AM
Beginner
Thanks - Just ordered the parts.
2003 S manual
11-24-2017, 08:51 PM
I *personally would replace all 4 upper shock mounts also..
11-25-2017, 07:37 AM
Yes, I agree with Brad, your fronts probably have cracks, mine did after around 110,000, my backs didn't but I think they had been previously replaced. Lemforder makes a front, but I only ever going oem.porsche for the back.
The front tuning fork arms are hard to find, but they are a match to 997 rear track arms, I discovered this on the Meyle website on the page for their arms. It matches 986 front, 996 all 4 corners, 997 rear.
