Old 07-24-2017, 07:18 PM   #1
Radio Issue
I just had the original radio replaced with new GPS/Radio/Bluetooth etc. Every time I turn the car off the radio system resets all settings and they go back to the original factory configurations and it goes back to demo mode.
Is this somehow connected to the security system and unusual battery issues with Porsche?
Denham33 is offline   Reply With Quote
Old 07-24-2017, 07:38 PM   #2
No. Sounds like the switched power and constant power memory wire are reversed.
Old 07-24-2017, 07:39 PM   #3
What did you use for an adapter harness? I'm no stereo expert but I'm wondering if the radio has no power when the car is turned off.
__________________________
'58 356A coupe, just a driver
'00 Boxster S fair weather - daily driver
'11 Jeep Grand Cherokee Limited - winter daily driver
'92 F250 - junk hauler; previous Porsches '95 993;'08 Cayman S;'70 911E
356Guy is offline   Reply With Quote
Old 07-24-2017, 08:44 PM   #4
This is a very common problem. Yes, your constant power and switched power are reversed. It doesn't mean you did anything wrong, they are just reversed from what the schematic says. Use a voltmeter to check if you want or save some time and just swap the two wires and be done with it.
Been there done it!
dghii is online now   Reply With Quote
Old 07-25-2017, 11:44 AM   #5
The harness I had mapped the wires properly so that the radio had constant power.
Old 07-25-2017, 01:53 PM   #6
I get it. So did mine. Swap the wires, problem solved.
Old 07-25-2017, 08:09 PM   #7
Thanks for the information. I didn't install it. I had car stereo place install it. I will get the wires fixed. I love this board
