Old 02-08-2017, 02:08 PM   #21
Originally Posted by Camibox View Post
Update: So I replaced the CPS. I didn't test the new one before I replaced it but tested the old and had no continuity between any of the pins (all read OL). Went to start the car and cranked but didn't try to catch. Saw the tach rise slightly but realized I never heard the fuel pump. Pulled the relay and put in a switch to test. Fuel pump activated. tried the car and it fired right up. 4 times and fired up every time. Wife says "Huh, bad relay". One of the first thing I did was replace the relay but it couldn't hurt, right. Replaced the relay and 3-4 more tries, no issue. We'll see how it goes when we try again tomorrow. BTW, I did test the relay I removed and it activated when I put voltage to the coil.
Called it. glad it was just that. Then again having a having a bad CPS may lengthen starting but not prevent you do drive. CAS is a must.
Best DIY testing method is starting with the cheapest issues first. If it doesn't help keep working at it.
2001 Boxster S (SOLD)
1991 Nissan Silvia "K"(Forgotten somewhere in Canada)
1989 240sx (Track car)
1987 325IS (Soon to be Spec E30 racecar)
2001 GSXR-600 (Almost warm outside!)
WorkInProgressK is offline   Reply With Quote
Old 02-08-2017, 02:14 PM   #22
The weakness in our relay test was that nobody insisted on wiggling the coil pins during the resistance test. The relay tested perfectly.
It is possible that the loose pin was caused by an overheating coil in the relay or arcing contacts ? Hence the suggestion to feel if it got hot.
Anyone got a circuit diagram for the fuel pump fuse - just to close the loop ? The 5th pin, the small one is the oddity.
http://www.pelicanparts.com/cgi-bin/supertech/catalog.cgi?action=frameset&return-url=/cgi-bin/supertech/catalog.cgi%3Faction%3Dframeback%26page%3D529&catalog-url=http%3A%2F%2Fwww.pelicanparts.com%2Fcatalog%2F SuperCat%2F1048%2FPOR_1048_FULFUL_pg2.htm%3Futm_so urce%3DSuperTech%23item8
Old 02-09-2017, 08:37 AM   #23
Well I did say to bypass the fuel pump relay entirely. But you are right that you would not have know what was at fault on the relay unless you opened it.
Wow, that tab. It just looks like porsche decided you couldn't use a standard 30 amp bosch relay which i am certain is identical inside. Their solution is to change one tab to a smaller one and turn one 90deg.
If you have a soldering iron, you could open it up and re-solder the joints.
Old 02-09-2017, 08:40 AM   #24
But it is not a 4 pin relay so the 5th ,small prong must be NC ?I agree ,it would be interesting to dissect it and observe the reason it failed.
Old 02-09-2017, 10:34 AM   #25
Well the difference between a 4 pin vs a 5 pin is just that the 5 pin allows 2 functions: normally open or normally closed. Once you have decided what type of relay you need you can trim off the 5th pin, which Porsche did. That one is a normally open considering the function and the schematic on the side of the relay.
Old 02-10-2017, 10:33 PM   #26
Camibox
Camibox's Avatar
Well opened up the relay. The "loose" prong was not an issue, but, one of the connections to the relay coil was just laying on the connection but not soldered on. Glad I bought 2 when I ordered
Camibox is offline   Reply With Quote
Old 02-11-2017, 05:03 AM   #27
geraintthomas's Avatar
Glad you've sorted out the problem bud, it's gut wrenching when you get a problem like this. Happy days!
Porsche Boxster S Type 986
Bi-xenon Headlight Upgrade | 987 S 18" Anthracite Alloys | Android Head Unit | 5000k 55w HID's | 5000k Cree DRL's | 5000k Cree number plate lights | Cree LED Indicators | One-touch roof operation | Bypass exhaust pipes | Parking sensors | Ambient footwell lighting
geraintthomas is offline   Reply With Quote
Old 02-11-2017, 09:17 AM   #28
Always good when a thread concludes with finding the fundamental cause of a problem.Thanks for sharing.
