Old 12-13-2016, 08:22 PM   #1
jaykay's Avatar
Best hub studs and lugs
I am looking for some quality hub studs maybe with polished bullet noses...also titanium lug nuts. The whole think has to look good as well.
Need to replace my beat up lug bolts
986 00S
Old 12-13-2016, 08:41 PM   #2
MSI makes top quality studs IMHO. That's what I use on my SPB:
MSI Racing Products
spendy is offline   Reply With Quote
Old 12-13-2016, 10:17 PM   #3
I have Rennline studs and nuts installed on my car but they only come in black and look like the MSI's.
I did find this titanium set on the 6SpeedOnline forum but don't have any personal experience with them:
Titanium Wheel Stud Kit - 6SpeedOnline - Porsche Forum and Luxury Car Resource
World Motorsports -Titanium-Wheel-Stud-Kit
Old 12-14-2016, 03:44 AM   #4
WillH's Avatar
I use these bullet nose studs Apex Competition Systems - Auto Racing Parts and Equipment
Old 12-14-2016, 07:23 AM   #5
steved0x's Avatar
Originally Posted by WillH View Post
I use these as well, I use the 65mm "Race Series" that don't have as prominent of a bullet nose.
Old 12-14-2016, 01:31 PM   #6
jaykay's Avatar
Thanks Gents I will go through all of your suggestions!!
Tom, astetically the world Motorsports kit you found is exactly what I was looking for! Design wise I would have liked to see more of a step transition between back and front threads; perhaps there are issues with clearing the brake rotor through holes.
I do also wonder about the durability of titanium stud vs chromoly; although I have caught some traffic rennline studs failing.
-is more of a step transion needed such that the stud buts up against the hub surface?
-is TI recommended for the stud application?
986 00S
Old 12-14-2016, 05:50 PM   #7
AZ986S's Avatar
I just installed the Rennline studs and nuts. Good price, bulletnose tip. You have to double nut them and make sure you use high temp threadlocker...
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
Old 12-14-2016, 10:01 AM   #8
I use Motorsports Hardware
https://motorsporthardware.com/
