					Originally Posted by JFP in PA  While you can activate the system using the Durametric, it is not set up- to read voltages.  That would be better accomplished with a multi meter or Power Probe tool. |
Yes, my bad attempt at brevity. That's what I meant when I said "test" for voltage. However it seems like a simple test for continuity and command from the DME.
