Old 08-23-2016, 07:59 AM   #1
Maf pin outs anyone?
I'm trying to diagnose my p1128/1130 for smog. Tried checking for air leaks and cleaned Maf but no go. Search doesn't get me any info on Maf pinouts for DVM checking. All I ever see is how to clean or replace. Anyone know the actual pinouts for Meter? Don't want to throw $$ at it to find my original Maf is ok.
Lapister is offline   Reply With Quote
Old 08-23-2016, 01:05 PM   #2
You have also cleaned the throttle body and run it enough to relearn the fuel trims and reset the ready codes?
Old 08-23-2016, 02:52 PM   #3
This has been going on since my upgrade to 996TB 997T and 987 intake. Car runs so much better but can't shake this code. It always happens at idle. I can drive a hundred miles or so then codes. Thought maybe I need more fuel and I may need a higher pressure regulator cause of the larger TB but others that have done this mod have never complained. If I can rule out this Maf as good electronically I'd move on to other pastures.
