Old 08-03-2016, 01:02 PM   #1
Red face Boxster Electrical Problems?
Hi, have a 97 Boxster 2.5, (RHD) generally great condition, but I have some weird issues with the electrical circuits and/or sensors, one that is baffling me is when I open or close the passenger window the heated screen switch light comes on, is this something normal or is there a problem with the cabin temperature sensor?
Also since radiator replaced last year have no heating unless set to maximum (HI), for example set to ‘24’ with temperature set to ‘AUTO’ the blower speed goes up to almost full but just blows out cool air!
Any help or guidance greatly appreciated?
tolmar1 is offline   Reply With Quote
Old 08-03-2016, 01:24 PM   #2
Originally Posted by tolmar1 View Post
…one that is baffling me is when I open or close the passenger window the heated screen switch light comes on, is this something normal or is there a problem with the cabin temperature sensor?
Not normal.
Is the exterior temperature sensor in the front bumper installed correctly?
Regards, Markus
Old 08-05-2016, 05:14 AM   #3
Hi Markus,
Thanks for getting back to me. Yes; have checked the position of the exterior temp sensor in the front bumper, seems ok. Is it worth replacing just to see if the replacement deals with the problems?
Mark
Old 08-05-2016, 08:54 PM   #4
Search two issues =
1. Earthing problems caused by corrosion- you are in a damp corrosive environment
2. Instrument/dash problems particularly the ignition switch.Yes it sounds silly but that darn switch can cause all sorts of weird and intermittent problems.
Old 08-06-2016, 12:44 AM   #5
Hello Mark,
climate control problem: The climate control system needs 2 temperature signals. One is the sensor outside the car in the front right (LHD) of the bumper. The other is the interior temperature sensor. If one of these sensors isn't connected correctly or doesn't work correctly, the climate system doesn't work correctly.
As far as i know the climate system isn't monitored by PIWIS in a 97 car. But you can check the complete sensor system if you have a digital multimeter system. For details see Porsche workshop manual - Heating diagnosis.
Regards, Markus
Old 08-06-2016, 02:44 AM   #6
I think everything is connected though... instrument cluster wont show mileage nor any info and needles don't work, windows wont go up or down, spoiler wont got stuck up and cant go down... all relays are ok.. does it have a seperate ecu for those parts? please help ! R Programming Training | DataStage Training | SQL Training | SAS Training | Android Training | SharePoint Training
2000 porsche boxster
thanks
https://www.gangboard.com/business-intelligence-training/r-programming-training | https://www.gangboard.com/etl-training/datastage-training | https://www.gangboard.com/database-training/sql-training | https://www.gangboard.com/business-intelligence-training/sas-training | https://www.gangboard.com/app-programming-scripting-training/android-training | https://www.gangboard.com/microsoft-training/sharepoint-training
andrajoseph is offline   Reply With Quote
