Old 07-17-2016, 03:42 PM   #1
B6T
Airbag light reset
I pulled my door airbags out to rebuild my window regulators. I can't reset my airbag light with my... ahem... "eBay diagnostic tool".
Getting a message that pertains to an unresponsive controller, or something like that.
Anyone have any experience with this?
B6T is offline   Reply With Quote
Old 07-18-2016, 10:04 AM   #2
I know others have added a resistor across the terminals of the connector to turn off the light. I want to say it was a 3 ohm resistor but if you have a multi-meter I would check the resistance of the removed airbag and use the corresponding resistor.
quick986 is offline   Reply With Quote
Old 07-18-2016, 02:11 PM   #3
Couple of points:
Very few diagnostic tools can turn off an air bag MIL lamp once the car is in fault mode. You need access to a Porsche specific tool to do this.
The resitor trick is not designed to reset a fault MIL, it is to mimic the air bag and prevent it being tripped. Once it is lit, you need the diagnotic tool, the reistor will no longer help you.
