Old 07-08-2016, 03:28 PM   #1
Rennzenn
j.fro's Avatar
Engine stand options ??
Ok, I need to pull the M96 from my 996 so I can remove the heads (oil in coolant, traces of coolant in oil).
What are the pros/cons of the stands out there??? I'm not looking for a hoist, just a stand. I've seen the Harbor Freight units @ <$60 and others at >$300. Hopefully I'll only need to use this once for a couple of months.
Rennzenn
Jfro@rennzenn.com
Old 07-08-2016, 03:38 PM   #2
jsceash's Avatar
I've used the cheap Harbor Freight one for 2 engine rebuilds. I've also just added 6 washer on the bolts to allow more space on the rear of the engine.
Old 07-08-2016, 03:40 PM   #3
BYprodriver's Avatar
Any stand should work, but the main consideration is stabilizing it while torqueing the head bolts & ease of bolting the case to the stand.
Old 07-08-2016, 03:58 PM   #4
JFro, is there a posibility that your heat exchanger (oil cooler), failed?
Old 07-09-2016, 03:02 AM   #5
Rennzenn
j.fro's Avatar
That's a possibility, along with the AOS leaking oil into its coolant line, but those are long shots. It's probably either a head gasket or cracked head. No matter what, it looks like the engine is coming out of the car.
Rennzenn
Jfro@rennzenn.com
