Old 06-22-2016, 06:55 PM   #1
GTA_G20's Avatar
Check engine code P0011
So I bought a new car '04s and it has this code which I pulled. I erased and in 20 mins it came right back. First time I test drove it was fine. This time I drove it and it stalled all the way home. Any help is appreciated
GTA_G20 is offline   Reply With Quote
Old 06-22-2016, 11:15 PM   #2
Steve Tinker's Avatar
P0011
Fault code 332 - Camshaft position with respect to crankshaft bank 1.
Could be expensive, could also be damaged wiring. Use the search function for a couple of opinions.....
2001 MV Agusta F4.
Old 06-24-2016, 07:27 PM   #3
Sorry, nothing to add.
Old 06-25-2016, 10:08 AM   #4
There are a number of possibilities like stretched chain,worn tensioner pads,tired tensioner,slipped cog on the camshaft drive etc. All speculation and pointless. too.
Best advice is find a competent local Indie(ask here) who does lots of M96 work.Don't drive it until it is positively diagnosed by an expert.
Old 06-25-2016, 10:44 AM   #5
P0011 indicates the cam deviation value on bank 1 has exceeded 10 degrees, which is excessive (spec is +/- 6 degrees). You need to park the car until this can be evaluated.
