Old 06-22-2016, 11:08 AM   #1
Maintenance recommendations?
I'm new here. I have a '98 Boxster. Just turned over 40K Miles. I've owned it for many years and never took it to a dealer, and don't intend to. I've replaced the ignition switch, and I need to do the window winders. (I have changed the oil too.)
What other recommended maintenance do you recommend? I assume it's time for belts, but what else? I'm assuming there are lots of little special things that only you guys know about.
I'm a skilled auto restorer, but the Boxster has always been the one car that I didn't have to restore, so I never touched it. But it's getting dusty under the hood. I do have the Pelican Project book.
Thanks!
EFLEXTER is offline   Reply With Quote
Old 06-22-2016, 11:35 AM   #2
Welcome to the forum.
Just use the forums search function: 986 Forum - for Porsche Boxster Owners and Others - Search Results
Regards, Markus
Smallblock454 is online now   Reply With Quote
Old 06-22-2016, 01:27 PM   #3
Pay attention to the Porsche maintenance schedule. 15, 30, 45, 60k mile services etc...
The 15s are smaller services, the 30s are larger services. I'd probably start with a 30k service especially if you haven't done it. Also look at tires. Depending on their age they may need to be replaced. After that, changing the oil at least once a year, 5000k mi max should be your norm. Hopefully you've been doing that anyway?
Welcome to the forum. Great resource.
Old 06-22-2016, 01:35 PM   #4
Gear lube changed
Coolant flush
Brake fluid flush
Replace thermostat
Replace waterpump
Replace spark plugs
Replace serpentine belt
That will keep you busy for a while.
Old 06-22-2016, 01:56 PM   #5
I can't believe my "new" car is almost 20 years old. It really got me thinking about things that need replacing from simple age, not miles. Thanks for the replies!
Old 06-22-2016, 09:18 PM   #6
There Is No Substitute.
rick3000's Avatar
Wow, that is extremely low mileage for a '98. I hope you have been doing annual maintenance. Letting these cars sit can be worse than putting a ton of miles on them. I would definitely do a full inspection of the car, especially anything rubber or flexible that could have hardened (coolant hoses, serpentine belt, etc). When I purchased my '99 in '07 it had gotten less than 2k miles per year, and I had some initial issues related to the car sitting around too much, like fuel that had crystalized in the fuel line.
You can find a recommended maintenance schedule here:
Maintenance Schedule - Porsche Boxster (986) FAQ
Old 06-23-2016, 06:09 AM   #7
My biggest concern was the sound the engine makes on start-up after sitting for a while. Clearly it's the sound of an engine that the oil has entirely drained out. A few years ago I started using Royal Purple oil which works better at clinging to the engine parts for long periods. Now the start-up is not so traumatic for the engine.
Otherwise, I think it's time for complete change out of rubber parts, fluids and a few other things suggested here. Thanks for the info!
Old 06-28-2016, 03:35 PM   #8
Administrator
In case you haven't already seen these, the tech articles we have on the Porsche Boxster can be helpful: Porsche Boxster 986/987 (1997-2004) Technical Articles | Pelican Parts
Also, to maintain any older rubber parts of your car's exterior (they might be drying out as well), you might want to take a look at Gummi Pflege Rubber Protection, which many of our other forum members have recommended.
Good luck!
Matt at Pelican Parts is offline   Reply With Quote
