Old 05-31-2016, 04:18 PM   #1
Leatherette Flap in Convertible Top Cavity - What is it?
I have a question. Went in to change the air filter. When I put the top in the service position I noticed a black leatherette thing with stretchy straps on the end and a black channel across the top. It was just laying in there. What is it? Need a pic or does someone know?
Jthoms1 is offline   Reply With Quote
Old 05-31-2016, 04:31 PM   #2
Ben-Auto-Design
Ben006's Avatar
Post a picture please
ASE certified Automotive Master Technician.
Porsche Tech in France.
www.benautodesign.fr
Ben-Auto-Design : Performance parts for 9X6 / 9X7
1982 928 S Euro
Ben006 is offline   Reply With Quote
Old 05-31-2016, 04:36 PM   #3
911monty's Avatar
Based on the description, I'd say it's the hood portion of a 2 piece bra. But probably the cover for your rear windscreen.
Old 05-31-2016, 05:15 PM   #4
Here's a pic
Old 05-31-2016, 05:17 PM   #5
98 Arctic silver 986
tommy583's Avatar
It channels water into the drains on either side of it.
Old 05-31-2016, 06:03 PM   #6
It's supposed to be clipped to the rear firewall. There are two small plastic clips back there, and the edge of the plastic channel just (gently, doesn't take much force) pushes into these two clips.
I think the purpose of this 'flap' is to keep the "finished interior" of the car separated from the potentially dirty / dusty / humid water-draining area of this cavity.
2001 Boxster
Old 06-01-2016, 01:13 AM   #7
Thanks gents....ill try installing it properly.
Old 08-27-2016, 02:43 AM   #8
Yeah so I still don't see how and where this clips on. On one "end" (the front facing) there is a tubular channel (you can see in the pic) that clearly clips onto something. Then on the back side, which clearly goes down, it also looks like it should be connected somehow. Logically it looks like it should form a "tent" so to speak to channel the water. Anyone willing to give me a picture of there's attached?
Old 08-27-2016, 04:56 AM   #9
steved0x's Avatar
https://m.youtube.com/watch?v=hCpiWmqC_6k
About 10 seconds in he shows the clips and then layer in the video it shows more detail.
Old 08-27-2016, 06:36 AM   #10
There Is No Substitute.
rick3000's Avatar
It slide up into the clips on the rear firewall. try to get them both in at the same time, and it can take a tiny bit of force (but not too much). It's an important piece to make sure water get's channeled to the drains, so don't leave it unclipped. Also make sure your drains are clear if you haven't already.
Old 08-27-2016, 12:48 PM   #11
Here you are, friend.
2001 Boxster
Old 08-27-2016, 06:27 PM   #12
steved0x's Avatar
Here is one of the drains, I have a little guard over it that I got from suncoast, it was relatively inexpensive and blocks things from clogging the drains.
Old 08-28-2016, 03:03 AM   #13
Perfect pics...I see clearly now how it installs. Thank you!!
