Old 06-26-2016, 08:07 PM   #21
Racer Boy
Racer Boy's Avatar
It seems as if the oil is leaking past/over the baffles and starving the oil pick-up tubes ?
If one of the hinged baffles was hanging up ,this is exactly the result that would occur.
Others have reported some mods required to fit the EBS baffle and avoid this and other issues. Did you check this?
EBS Racing oil sump baffle issue - Rennlist Discussion Forums
x51 type baffle that works with deep sump spacer kit
You might investigate "horizontal baffle" also. Tarret/Pedro/Technosump have that as part of their deep sump kit. If positioned correctly, it is very effective.
The EBS baffle fit with no problem in the area that the original poster had to trim. In the three years since that was posted EBS probably changed it. That said, I did have to do some trimming with a Dremel along the bottom to get it to fit perfectly. Once I got it mounted on the sump plate properly, I did check to make sure the hinged plates moved without any interference.
I'll investigate the horizontal baffle.
Old 09-08-2016, 05:33 PM   #22
Racer Boy
Racer Boy's Avatar
Today I ponied up and paid an independent Porsche repair place to replace my AOS, and since I thought that was the last thing to try and fix the smoking issue, I signed up for a track day next Wednesday back at The Ridge. Since that track has a lot of really long left-handers, it should be a good test to see if the problem was solved.
While I was waiting at home for the Indy to call me when they were done with the car, I was doing some more research into AOS problems. I stumbled onto this very informative thread - http://986forum.com/forums/general-discussions/36949-oil-cloud-when-running-hard.html, and there is a lot of discussion about the scavenging pumps in the cylinder heads. I started wondering if my passenger side pump was weak, because it makes sense that if the pump isn't functioning correctly, you'll get the smoke bombs in left-handers. Think about it - the scavenge pump is in the rear of the passenger side head, so after blasting down a straight at high revs, there is hard braking, followed by hard cornering to the left. The oil can't get sucked out of the head and returned to the sump quickly enough, and the AOS sucks the oil into the intake. On the driver side head, the pump is in the front of the head, so it can return the oil back to the sump easily.
My thought was to swap the pump side-to-side, just to see if that would make any difference. When I looked at the passenger side pump, I saw that it wasn't indexed to the head correctly! The pump has 1-3 (passenger side), and 4-6 (driver side) that is stamped on it. The bank that the pump is mounted on should have the correct stamping on the pump facing the crankshaft. As you can see by the picture below, it was mounted wrong! (The driver's side pump was mounted properly). It is quite possible that this has been my problem all along.
I took the pump out and installed it correctly. It looks like the pump was removed at some time in the past, as the mounting bolts were a lot less grimy than the rest of the engine. Since I have no idea of the car's past, it is a mystery why the pump was removed.
Once I finished with the pump, I went for a test drive. There is a very steep hill in my neighborhood, so I went down it at redline (in first gear) for about five seconds, then braked very hard, and then went right back to full-throttle. Not quite the same as being at the track, but I figured if the pump weren't installed correctly, it might have smoked under those circumstances. It didn't smoke, so at least I didn't make things worse!
The real test will happen next week at the track, but I'm excited that I found something that could be the root of the trouble! I'll check back and let everyone know if the issue has been fixed.
Old 09-08-2016, 06:21 PM   #23
The Prime Suspect in identifying the cause was ..........guess whoo....yup Jake !
"The pumps are also installed incorrectly in their bores or the body is disassembled and phased incorrectly into the housing."
"Is the pic of the scavenge pump taken on bank 1 or bank 2 of the engine? Its not totally clear.
Have you taken the scavenge pump apart? It is symmetrical and the body can be assembled out of phase and still fit, but have this symptom.
Here is a reason why the mistake may have occurred -I stumbled into it when I rebuilt my engine. I was fanatical about marking everything with a paint pen. Both scavenge pumps look identical - but they are not -quite Unless you have studied the long Post by Insight on Timing as if your life depended on it ,you could easily miss it as a noob. I did but luckily caught myself.
This is a good example of the standard of work required on these cars. If you think it is "just nuts & bolts-like any other car" ,you'll fail.
Kudos to Jake and Racer Boy for doing the research.Thanks for Posting this because we tend to fixate on the AOS and X51 baffles for symptoms like this smoking.
See pge 7 photos, Post 91 scroll down for the exact photo required here:
http://rennlist.com/forums/996-forum/672370-engine-rebuild-part-3-the-finale-7.html
See Waynes comments alongside Fig 25 here:
http://www.pelicanparts.com/techarticles/Boxster_Tech/16-ENGINE-Camshaft_Swap_and_Chain_Tensioner/16-ENGINE-Camshaft_Swap_and_Chain_Tensioner.htm
and
http://www.pelicanparts.com/techarticles/Boxster_Tech/Disc163/BoxsterTech-163.htm
Old 09-08-2016, 06:22 PM   #24
911monty's Avatar
Good find. Indexed as it was the discharge port was no longer positioned correctly. I had started thinking along this line after reading your posts. I have attached your thread to patssie's thread about AOS hope you don't mind. Today I searched scavenge pumps and apparently this is not uncommon.
Old 09-09-2016, 07:05 PM   #25
steved0x's Avatar
Good catch, I hope that fixes it!
Old 09-14-2016, 09:00 PM   #26
Racer Boy
Racer Boy's Avatar
As promised, here is the update after doing a track day today. It didn't smoke! Looks like indexing the scavenging pump correctly solved the issue. Phew!
I really thrashed the thing today, and it ran just great without any issue. I guess I won't sell the damned thing after all, and I've even started to allow myself to like the car a little bit. But just a little!
It turns out the $99 for the set of rotors from China don't work well at the track, warping enough to cause severe juddering, and the pads faded badly, so I had to ease out of the gas way before the turns and brake early. Despite that, I was able to reel in a 2002 911 (he eventually spun, no doubt from me pressuring him ), and a new 911 blasted past me down the straight, but I was quicker in the turns, despite the huge tires that car has. So I feel pretty good about things. Not having to worry about the smoking allowed me to focus on my driving and learning the track, so that was fun!
My daughter lives nearby, so she came out and I gave her a ride for one session. She felt very nauseous afterwards, so that was a positive as well; if I made my kid sick, I must be doing something right!
That will be my last track day this year, so over the winter I throw some decent rotors and EBC Yellows at the car, and I'll start looking for some M030 roll bars. But I'm really happy to have a car that functions as it should on track!
Old 09-15-2016, 05:02 AM   #27
steved0x's Avatar
Great news!!!
JayG has had some success with the Meyle rotors which are very affordable, and I think at this point he has had some track days on them and can report how they did. Meyle makes good stuff, I have some of their suspension parts on my car and have been happy with them.
Always a bonus Reeling in the more powerful cars is always a lot of fun
Old 09-15-2016, 06:02 AM   #28
RacerBoy, you may want to try the Pagid Yellows instead with new rotors
these will squeal like pigs but will stop you and will not fade
Old 09-15-2016, 08:08 AM   #29
M030 roll bar
Suggest you also Search for "Lower Stress Bar" or Pedro bar . There is a $10 diy version also
Zimmerman rotors + Pagid?
Old 09-15-2016, 08:53 AM   #30
Fantastic to hear the smoke bomb issue is resolved. I admire your persistence. A lot of folks would have said "screw it" and put the car on Craigslist.
I had the pleasure of being on track in a 911 with a Boxster in hot pursuit. I would pull away fast on the straight, only to have him squeeze by me in the turns. We both thought we were pretty cool until an off-duty Skip Barber instructor absolutely SMOKED both of us in his spec Miata. We might as well have been driving golf carts.
Need_for_speed is offline   Reply With Quote
Old 09-15-2016, 09:01 AM   #31
Way to go in finding (and fixing) the root cause of this issue! It sounded like it was pretty aggravating. Congrats, and thanks for sharing!
2001 Boxster
