Old 02-08-2016, 08:07 AM   #1
Engine Virbrations @ 3,100 RPM in 4th & 5th
I have noticed an engine vibration in my 2002 986 (2.7L) when the RPM's are dropping and hit around 3,100. The vibration occurs in both 4th and 5th gears. There are no noticeable vibrations when accelerating, just when I let off the gas pedal and the RPM's drop. The vibrations begin almost exactly between 3,150 and 3,050.
I plan on replacing the Air/Oil separator in the next few weeks but I wasn't sure if a bad AOS could be causing the engine vibrations or not.
This 986 is mechanically stock and has never been tracked.......yet.
Thanks in advance
-Michael
Highrise is offline   Reply With Quote
Old 02-08-2016, 08:14 AM   #2
98 Arctic silver 986
tommy583's Avatar
It sounds like you need to change your motor mount. You are having a classic symptom of a worn motor mount.
Old 02-08-2016, 08:22 AM   #3
That's definitely it!
After a little googling, one of the other common symptoms of a bad engine mount is the gear shift moving back and forth under acceleration, which mine does.
Thanks for such a quick reply, looks like I have a new weekend project.
Old 02-08-2016, 07:33 PM   #4
1999 base
Meir's Avatar
Tip.
Job is much easy when removing the coolant hoses.
Good oportunety for coolant flush as well.
Old 02-17-2016, 08:57 AM   #5
Has anyone had any experience with just replacing the bushing and not the whole mount?
The entire engine mount assembly isn't too expensive ($156), but it never hurts to save a little cash if I can just replace the bushing for $40.
The bushing assembly is made by Lemfoerder, but I haven't found much information on them. http://www.amazon.com/Lemforder-Engine-Mount-Bushing-Only/dp/B004PAG1DQ/ref=pd_sbs_263_1?ie=UTF8&dpID=51W21lsPdYL&dpSrc=sims&preST=_AC_UL160_SR138%2C160_&refRID=0WRHKTF9W1GBYC3DCR8D
Is it worth the hassle of pressing in the new bushing or should I just replace the entire mounting assembly?
Old 02-23-2016, 05:03 PM   #6
I used the bushing assembly and it worked fine. Tool guy at work
did it with a heavy duty vise. Good way to save a few bucks and the old
frame looks like it will never wear out.
jeffL is offline   Reply With Quote
