Old 01-07-2016, 06:26 PM   #1
roocox@gmail.com's Avatar
Trouble with Key, Can't Start Car
I'm having trouble with my key. It just won't turn into the on position, and I think it's the actual key. The key does work in the door locks. It's hard to see in the pic below, but there's a thin wall of the key groove that is sort of bent/collapsed. The other side of the key is fine. I tried replacing the ignition switch because it was easy. And the key FOB battery. But it definitely feels like a mechanical issue.
What does it cost to have a new key made? Can a locksmith do it?
I can't get the lock cylinder out with a paperclip because the key won't turn that far. Otherwise, I could just replace the whole lock assembly. Or can this still be done? I've seen whole assemblies with key sell for about $100 on eBay.
Note this is race car build, and rules state that I have to keep the key assembly, but I'd be happy to learn how to just permanently bypass the whole thing and not have to worry about it, so it would just be there for looks.
roocox@gmail.com is offline   Reply With Quote
Old 01-07-2016, 07:36 PM   #2
flaps10's Avatar
Check the "Key replacement woes" thread. The metal part is cheap. Plus, you could probably use a small rotary file and remove the thin part bent into the groove.
Old 01-08-2016, 11:28 AM   #3
Called the local porsche dealer, only $50 or so to have a new key cut (w/o FOB). Hoping this resolves my issue. Will report back after I get the key made.
Old 01-09-2016, 05:11 AM   #4
Sounds to me like an ignition switch issue.
Old 01-09-2016, 06:45 AM   #5
Replaced the switch already.
Old 01-09-2016, 10:33 AM   #6
Sorry I see that now. It's odd to me that the key binds up in the ignition switch but works fine in the door.
Old 01-12-2016, 04:38 PM   #7
Got a fresh key (blade) from dealer for $45, still won't turn over in the ignition. I'm thinking it's something in the tumbler.
-replaced key
-replaced ignition switch
I almost have my dash out, needed to come out anyway for race prep.
What's are my next steps here or next parts to replace? I can't get the tumbler out (using a paperclip) because I can't turn the key over to the On position.
Can I disassemble the tumbler and repair it? Again, this is for racing, so even if I could smooth out the pins inside tumbler, that would work.
Does anybody know the steps toward bypassing the ignition all together for operation? I would have to keep it in place for looks, per rules of the spec class. But I think I could just not use it.
Old 01-14-2016, 05:18 AM   #8
I FINALLY got the key to turn by placing a spare key blade in the mysterious second key hole that was revealed once the dash was out. What's going on here? I'm considering replacing the ignition housing and keeping the cylinder/key to avoid any future problems down the road. Any suggestions?
Old 01-14-2016, 06:12 AM   #9
Second keyhole? Whoa, maybe it's like a hidden portal to activate the warp speed function?
