Old 11-07-2015, 10:44 AM   #2
If you replace the whole cluster, then both the odometer and the VIN would have to be changed to match yours. However, you can change just the faces by swapping out only the front half of the cluster. This is very quick and easy to do and does not require major disassembly of the cluster.
