Old 11-03-2015, 05:18 PM   #1
05 boxster 2.7 will not start
so I pulled the drivers seat out, and the module below the seat out to rescue some jewelry my wife dropped under the seat. Now after putting it back together the car wont even attempt to turn over and has all sorts of error messages on the cluster.
What gives?
2013grandsport is offline   Reply With Quote
Old 11-03-2015, 05:29 PM   #2
911monty's Avatar
Did you disconnect the battery before you disconnected?
Old 11-03-2015, 05:41 PM   #3
Beginner
Jamesp's Avatar
What I would do:
Disconnect the battery
Take out the seat again
Pull everything apart
Check to be sure you've accounted for all connections, that they are all fully connected.
Check each connector for bent pins or bad connections (trash caught in the connector, etc.)
Carefully re-assemble everything looking for any missed connections or mistakes that could have happened the first time though.
connect the battery
Best of luck!
2003 S manual
Old 11-05-2015, 11:02 AM   #4
I did not disconnect the battery before hand
