Old 11-08-2015, 05:04 AM   #13
Originally Posted by boxster View Post
I know I might sound stupid and that this has been discussed many times, but what about the ims retrofit bearing together with the oil fed flange from the ims solution? I know you obviously thought about this,but why is it better to run the retrofit on splash oil, would more oil do it more harm than good?
The LN bearing is designed to work without an oil feed system, and the flange from the IMS Solution will not fit with any ball bearing unit, it is designed to only be used with the Solution solid bearing.
