10-05-2015, 08:34 PM
#1
thud when shifting from first to second on a fairly hard acceleation from a stop
So when i shift from 1st to second, i get a thud after releasing the clutch and applying accelerator, doing a higher rev shift change...Any ideas as to what this could be a indicator of?...not spinning tires or anything, I don't do that..but what I like to refer to as spirited driving  ya know, the "Porsche experience"
Will
10-05-2015, 09:11 PM
#2
Replace motor mount.
10-05-2015, 09:27 PM
#3
ahh, ok, i'll do a search for videos on this, as not familiar to what that entails, thank you
Will
10-06-2015, 09:41 AM
#4
Project Addicted
If you have the tools and the skill, you can replace just the rubber part for cost of $35 or so. A full motor mount of the newest design is about $120 and is a bolt in job.
______
Jon
1966 912, 1976 911
1986 944, 2000 Boxster
10-06-2015, 10:07 AM
#5
This sounds great!....
is there a thread that i can view to see this??? what is the rubber part called, a bushing?
Will
10-06-2015, 10:19 AM
#6
Project Addicted
______
Jon
1966 912, 1976 911
10-06-2015, 08:22 PM
#7
I replaced the motor mount myself, royal pain in the ass without a lift. II think I'd rather spend $200 more and get it done by a reliable indie. Doing it yourself takes about as day with the car on jack stands.
10-07-2015, 07:17 AM
#8
I have to disagree...took me 2 hours. Just lift the back and put on jack stands as always (or use ramps). Put jack under engine, lift engine a few inches to take weight off of front mount, put another jack stand beneath the motor to relieve floor jack, unbolt mount and cuss a bit while you snake it through the coolant hoses. thats all there is to it. If it wasn't for the coolant hoses, it would be a 30 minute job.
10-08-2015, 11:13 AM
#9
I agree, just replaced mine this morning. Took about 2.5 hours and that was peckering around. A friend came down after the car was up on stands and we knocked it out painlessly. Now doing it, I think I can do it again in about an hour. Nothing really gave us any trouble, just got to twist and turn it the right way and its done.
10-19-2015, 08:48 PM
#10
You might want to do your water pump at the same time, if it's been a while.
10-24-2015, 05:41 AM
#11
Yes
Clickman that's a great idea and then you can disconnect the hoses to get them out of your way!! Love it!
