Old 10-22-2015, 04:42 AM   #1
Not horny
Hi All
I went to vent my frustration at someone who cut me up this morning only to find my horn doesn't work. When I push the horn I can hear the relay click so I guess it will be the horns themselves behind the front bumper. Before I buy them and dismantle the front of the car is there anything else I should check
Thanks for any advise
John
oldbones is offline   Reply With Quote
Old 10-22-2015, 06:18 AM   #2
Perhaps the "Mojo" relay is too old..?
LOL
Old 10-22-2015, 09:45 AM   #3
Just did this job. Horns are super cheap. When you see the location of the horns you'll see why they go out. Drive through a puddle and they'll be fried. My old ones had a ton of water in them. The hardest part of the job is getting the bumper off...I'll say this, there are more screws than pelican says there are...so if it seems like it's still hung up, there are more screws to take off.
The while you're in there job is to clean out your radiators. You'll be amazed at the crap you find.
Old 10-22-2015, 09:52 AM   #4
Me so horney
Old 10-22-2015, 01:20 PM   #5
Beginner
Jamesp's Avatar
Make sure you get horns that fit. They are small!
2003 S manual
Old 10-22-2015, 04:03 PM   #6
And you wouldn't want to be getting all horny just to find out your unit is too big.
Merlotsj is offline   Reply With Quote
Old 10-22-2015, 08:05 PM   #7
Perhaps this bumper removal guide will help:
https://www.youtube.com/watch?v=Um-h2aUJHY4
'99 black 986
Old 10-23-2015, 05:37 AM   #8
billj18's Avatar
Before you begin tearing things apart, try this: with the car off and the key out, try the horn. If it works, you have a ground issue in the steering column. A forum search should yield the details. If the horns don't work, your initial diagnosis is likely correct.
Bill
BJ's BlackBox -- 2001 Boxster
1997 SAAB 900S Turbo
1980 Maxda RX-7
1974 Fiat 124 Spider
1976 Datsun 260Z
billj18 is offline   Reply With Quote
Old 10-23-2015, 06:22 AM   #9
jb92563's Avatar
What are the chances of both horns failing. I would suspect loose/broken wires or grounding. Most likely grounding since as things corrode the ground is typically compromised.
I find the horn is not distinctive or suited to Porsche, just plain boring really so perhaps you have a good excuse to upgrade.
Something more European sounding perhaps.
Anyone heard a good horn lately.
Old style higher pitched dual trumpets perhaps.
Personally for a noisy warning device I like the guns switch myself
Old 10-25-2015, 05:13 AM   #10
landrovered's Avatar
I replaced my horns with Hella horns. They were larger so I took off the bumper cover and mounted them behind the aluminum front bumper. Plenty of room and a better location than stock position in my opinion.
2001 Boxster S 3.6L, Zeintop
"Calling upon my years of experience, I froze at the controls." - Stirling Moss
landrovered is offline   Reply With Quote
Old 10-25-2015, 06:31 AM   #11
jaykay's Avatar
Do they sound when you press the fob to lock.....with something open or has all the air disapated by then
986 00S
Old 10-25-2015, 06:51 AM   #12
There is a separate horn that operates this sound. Not in the same location.
Both my horns failed and replacing them restored normal horn operation. Just sayin'
Old 10-25-2015, 08:41 AM   #13
jaykay's Avatar
Good to know....this means one can put in twin air horns and disrupt the ajar warning
986 00S
Old 11-07-2015, 04:16 AM   #14
Fitted a used pair of original horns this morning now working. Also cleaned my rads at same time
John
