Old 10-15-2015, 02:05 PM   #1
Usercpy
ilikeching's Avatar
Steering wheel not center
Hi,
I just changed my left front coffing arm, the old one had some play, now the steering wheel is not center after installed the new one.
Is it normal? there were no "Spacer" alignment in front, only at the rear coffin arms(Control arm)
http://www.flickr.com/photos/flickr_ching/
ilikeching is offline   Reply With Quote
Old 10-15-2015, 03:58 PM   #2
Racer Boy
Racer Boy's Avatar
I'm not sure what a "coffing" arm is, but you probably changed the toe-in when you replaced whatever that part was. You need an alignment to correct the problem.
Old 10-15-2015, 05:08 PM   #3
Usercpy
ilikeching's Avatar
Hi, i was writing wrong, its coffin arm(they call it because it looks like coffin) its lower control arm.
Old 10-15-2015, 07:48 PM   #4
steved0x's Avatar
+1, a front end alignment can fix that. I would mention it to them or they might "fix" the other side and leave you with a crooked steering wheel.
Old 10-15-2015, 11:17 PM   #5
Steve Tinker's Avatar
When you installed the coffin arm, did you lower the car on its suspension before you tightened the bolt securing the arm to the chassis? The arm must not be tightened with the suspension in the "hanging" position but as it sits on its wheels.
2001 MV Agusta F4.
Old 10-17-2015, 05:32 AM   #6
Xpit77's Avatar
I just had both arms replaced along with the sway bar links. It also had a off steering wheel.An alignment fixed it. Unfortunately the rear is on the limit for any more adjustment . But my guy says it`s fine and it is a 16 yr old car.
99 Boxster sold
88 944S sold
Xpit Formula Four sold
95 Integra Solo I sold
71 Opel GT sold
Old 10-23-2015, 11:18 AM   #7
Usercpy
ilikeching's Avatar
No, i did not, Thanks for the tip
