Old 10-13-2015, 04:42 PM   #1
Loss of Day Time Running Lights
Hi there,
Have a 99 Boxster and my day time running lights have quit functioning.
Regular head lamps and marker lights all work just fine with the turn of the light switch. Fog and Rear Fog are also OK.
If anyone can lead me in a few directions to start hunting down the cause I would really appreciate the help.
Duezzer is offline   Reply With Quote
Old 10-13-2015, 05:30 PM   #2
CHRISP357's Avatar
I would suspect the headlight switch.
CHRISP357 is offline   Reply With Quote
Old 10-13-2015, 06:41 PM   #3
You have day time running lamps in your 99?
Old 10-13-2015, 06:59 PM   #4
On the slippery slope
JayG's Avatar
They are std for cars in Canada
Try cleaning your headlight switch
Basicially remove it from the car and spray inside it anywhere yo can and down the shaft with contact or tuner cleaner. Then move it between all of the possible positions a bunch of times. Shake it out. Let it sit for a few minutes to let the cleaner evaporate and reconnect the switch and see if that fixed your problem
2004 996 Targa Tip
Instructor - San Diego region
Old 10-13-2015, 07:46 PM   #5
I just took my switch apart due to loss of litronics on both sides. I used a small screwdriver to seperate the two halves of the switch. Although the contacts didn't look bad, I cleaned everything with contact cleaner, pencill eraser and 320 grit sand paper.
All is working (at the moment).
dghii is online now   Reply With Quote
Old 10-13-2015, 08:18 PM   #6
JayG's Avatar
you are a braver sole than me taking the switch apart
2004 996 Targa Tip
Old 10-13-2015, 09:12 PM   #7
I had to replace my e-break handle the pot metal broke - is there a connection in their that I may have missed reconnecting - most DRLs are shut off when e break is engaged.
Is the Porsche set up the same way?
Old 10-14-2015, 03:50 AM   #8
Rennzenn
j.fro's Avatar
The Canadian cars have a relay for the DRLs and this may have failed. The relay is located with the other relays near the fuse panel, and I believe it is a large relay similar in size to the top rely.
Rennzenn
Jfro@rennzenn.com
Old 10-14-2015, 07:18 AM   #9
Thanks J.Fro
