Old 09-28-2015, 07:49 PM   #1
On the slippery slope
JayG's Avatar
Brake flush amounts
I'm getting ready to do some track days and want to replace my brake fluid before I go. My current fluid is clean, so it is almost impossible to tell when the "old" fluid is out and the new in. That is why I want to do it by measuring the amount.
Last time I bleed and flushed my brake fluid, I found a post that specified how much fluid per caliper. I do remember it did add up to less than a liter.
I can't find that thread again
Does anyone know how much fluid you need to push through each caliper and the clutch slave to full replace the fluid?
2004 996 Targa Tip
Instructor - San Diego region
Old 09-28-2015, 07:59 PM   #2
Pdwight's Avatar
This would be a good stickie for reference. I am about to flush my fluid as well (Original as far as I can tell)
Old 09-28-2015, 08:07 PM   #3
steved0x's Avatar
Are you a member of the Boxster register? They have an article on brake flushing with exactly what you are asking. You have to have a login to see it though I think.
PCA Boxster Register
In this article he bleeds 6 ounces out of each rear caliper (3 oz per bleeder) and 5 oz out of each front, to get a complete flush.
I am about to do a flush as well but luckily(?) my old fluid is dark from use so it is easier to tell
I recently had to bleed my front driver side and before I did I pushed the caliper pistons back using a brake pad spreader tool. I figured this would help me flush the old fluid that was in the caliper closest to the piston. When I bled I got a slug of ate blue from a couple of flushes ago... I am going to make this a part of my brake bleed workflow from now on. I also swapped my pads inside to out because the inner had less wear, I believe due to the cooling from my gt3 brake ducts.
Steve
Old 09-28-2015, 08:25 PM   #4
JayG's Avatar
I saw that one. The one I remember was in ML, not oz
Its interesting as the entire system is .4 liters or ~12.8 oz
6 oz is ~ 175 ML per rear caliper and 5 oz is~150 per front
That totals ~650 ml, so that makes a lot of sense
I saw another amount from someone and they were saying 500ml per caliper
That seem pretty high to me
2004 996 Targa Tip
